I’ll try to be brief! Using 2.14.3, aiming to only import logs. Have set PHP mem to 512, max_execution to 300, nginx fastcgi timeouts are at 14400.
[ul]
[li] import_logs gets stuck at 58036 lines each time
[/li][li] get the same error[0] repeatedly now, whether I use --recorder-max-payload-size=200 or not
[/li][li] restarting or reloading nginx doesn’t help it to reconnect (nor does it help to do the same with php5-fpm or mysql)
[/li][li] when I try to core:archive the incomplete import_logs I get MySQL server has gone away errors
[/li][/ul]
[0]
2015-10-08 15:31:09,782: [INFO] Error when connecting to Piwik: HTTP Error 500: Internal Server Error
2015-10-08 15:31:09,783: [INFO] Max number of attempts reached, server is unreachable!
Fatal error: HTTP Error 500 Internal Server Error, response: {"status":"error","tracked":9,"invalid":0}
You can restart the import of "/var/log/nginx/site.com_access.log" from the point it failed by specifying --skip=58036 on the command line.
This was actually working on an hourly basis yesterday. No records since 21:30 last night are being reported on the dashboard now. Things I’ve found to get the import_logs.py working are:
pkill -9 python
and starting over, or adding
--recorder-max-payload-size=200 --replay-tracking
I later removed --replay-tracking, but still no dice.
Thought I had it solved earlier today after this comment but no new visits were recorded by the cron-runs using those options.
Any thoughts on what I can do?
