I started using the DNS provided by CloudFlare and noticed some issues with Piwik. The first issue was that my Piwik page was blanki, I solved that excluding the page from CloudFlare (basically creating a page rule in my CloudFlare dashboard page).
The other issue is that the IPs of my visitors now appear as coming from CloudFlare IPs only. The location is correct as I see the proper flag (99% of my visitors come from Italy and I still see the Italian flag).
I read this (301 Moved Permanently) and this (301 Moved Permanently), but it’s not really clear to me what I need to do.
Could you please tell me what I need to have to what files and where they are? I’m a beginner so I would need idiot-proof instructions!
under the [General] section in the config.ini.php file in my piwik/config folder and it works - the IPs are the IPs of the visitors and not the CloudFlare IPs anymore.
mamaalda thanks for that. If you d like, it would be great to add a new FAQ “How do I configure Piwik for CloudFlare?” that would mention the whitelist + config file change. If you reply with the answer thta explains i’ll add it to FAQ thx!
Just to check all that I need to do is:
proxy_client_headers[] = HTTP_CF_CONNECTING_IP
And this will apply to all my sites that use cloudflare in piwik and do no damage to those that don’t use cloudflare in piwik?
