I’m running piwik since years on my IIS servers and never had an issue until now after I updated from Piwik to Matomo so it was a bigger jump in releases.
I always used the command line php for starting the archiving and it worked so far in the past but I’m stuck now with an issue which is puzzling me. I get the following errors shown:
INFO [2019-11-30 20:33:04] 45104 SUMMARY OF ERRORS
var divStr = ‘<input title=“Login to access network” type=“button” value="’ + mplang[’_Login’] + '" name=“Login” onclick=‘setData(false)’ /> <input title=“Login SSL VPN portal” type=“button” value=“SSL VPN” name=“Lo '>.forms[0].username.focus();;nding -->gin”)
script>
r>)“checkbox” style=“display:none;”/>
So no data will be archived.
I’m using the latest release, just downloaded it today. I’m also using php 7.2 but also tried php 7.0 and 7.1 without luck
The way I call the archive script is:
php.exe c:\websites\piwik.mydomain.ch/console --matomo-domain=mydomain.ch core:archive --accept-invalid-ssl-certificate
But I also used the old one which worked for years:
C:>php.exe c:\websites\piwik.mydomain.ch/console core:archive --url=https://mydomain.ch --accept-invalid-ssl-certificate
The only thing which is also new is that I have 2 Network cards in the system now and the SSL VPN button mentioned in the error message looks like the script is hitting the firewall page where also button is mentioned like this. This firewall is also the default gateway and the other card does not have a gateway.
Maybe someone can point me into the correct direction for solving the issue.
Thanks a lot
Andreas
