Is there an overview for tracked events?
I just saw the new event tracking API which comes very handy as I have to track some events on a website. Currently the feature is lacking a documentation, so I hope someone can help me.
For testing I tracked some events using the JS API and the events show up under “Visitors” > “Visitor Log”? Now I’m wondering whether this is currently the only place where they show or whether there is /will be something like an overview on events. How often they were triggered and so on?
Best Regards,
Flo
They are displayed under Actions > Events
use the latest 2.2.0 to get it: I would like to test early beta and RC releases, how do I enable automatic updates to use these development versions? - Analytics Platform - Matomo
Doc will follow
Thx for the fast reply. Currently I use Piwik 2.1. So I will upgrade it and check the overview.
Ah, where can I get version 2.2.0 from? I can only find the download link for 2.1.0. On GitHub there’s also no 2.2.0 branch.
Try http://builds.piwik.org/ !
2.2.RC3 is there…
Dali
