Is it possible to segment visitors on number on visits in period?
I would like to segment my visitors based on number of visits in the last 30d.
Segment A: All visitors that had < 3 visits in the last 30d.
Segment B: All visitors that had >= 3 visits in the last 30d.
Is that possible? I did not find a solution yet, but it sounds like it should be trivial. Any heads up?
Thanks in advance, Dirk
Hi Dirk,
you can create two segments with Number os visits Less Than x and then select the period for the last 30 days.
If both segments are created you can compare them within your dashboards if needed.
So what are you trying to do is to add three segments of one which will show less than a certain number and another which will show more. The last segment will show the number of days. Doing this will make things complicated and you will eventually need four segments to cover all these. I think it will not be possible.
