Internet Explorer and cross-site scripts
Hi guys,
I’m having a problem with not seeing any IE visitors in piwik stats.
The setup is :
website is on a.com
adserver is on b.com
piwik instance is on c.com
The website includes a script that loads the ad from the adserver, and also loads the piwik script.
I tried adding a p3p policy on c.com, but that didnt help.
There are no iframes involved btw. Tested with IE8. I see all other browsers in visitor logs.
HI,
The two first questions that come to my mind are :
[ul]
[li]Are cookies disabled in you Internet Explorer ?
[/li][li] In Piwik, Did you set the cookie to prevent page views from your browser ?
[/li][/ul]
Check these first and let me know.
jOoL
nope. default IE settings
nope.
I think this is happening because of the way I’m trying to use PIWIK, as embedded in an ad, instead of embedded in a page. Basically, I am using PIWIK to provide me client-stats on the pages where my ad appears, and hence including the PIWIK tag with my adtag.
IE has different third-party cookie rules (more stricter than other browsers).
I’ve been able to find a solution around the problem, using mod_rewrite, setting P3P policy, using setCustomUrl() and other functions, but it is still clunky and I was wondering if there was a more elegant solution.
