I am new to Piwik. I am having problem with the install process. I downloaded and installed Piwik and it completed the process. when I got the the last page that said Congratulation and Continue To Piwik. When I clicked it, it started over.
I have gone through it twice now and don’t know what is wrong. So I am asking for help here.
Okay guys, am I missing something here and if I am please someone tell. What does one have to do to get help from this forum? This is my first time here.
I am just trying to get a log in screen so I can log in to Piwik. Everything install successfully but not log in screen.
Someone, anyone please help me or give me some suggestions.
[quote=seeourweb.com]
Thanks.[/quote]
You check your config file or anything that was suggested?
Hello there everyone!
I just wanted to kindly thank you all for your great posts. By means of your explanations and help I managed how to install this program! Thank you very much for your advices!
I have an error while installing piwik in my site.
Can you please tell me solution for this.
I have attached an screen shots for that. Please please help me.
Thank’s
Amol[/quote]
Do exactly what it says…configure php with iconv support. To enable the extension you will have to rebuild with ./configure --with-iconv=directory then do a make, make install
