I’ve installed piwik with no problems but everytime I get to the ‘Continue to Piwik’ link it goes back to the start of the installation process. How do I get it past the installation?
Hi brent
check if the installation has created the configuration file. The config file is located in:
/config/config.ini.php
example: /var/www/piwik/config/config.ini.php
check if the superuser, database information is set.
Hi beta171,
Thanks for the help. The config folder didn’t have write permissions so didn’t create the config.ini.php file.
All sorted now.
Thanks
