Install issue - Cannot use output buffering in output buffering display handlers
(mahdi1234) #1
hi there,
I went thru the whole installation process fine, however now it throws the following error -
Fatal error: ob_start() [<a href='ref.outcontrol'>ref.outcontrol</a>]: Cannot use output buffering in output buffering display handlers in /st/core/ErrorHandler.php on line 31
PHP Version 5.2.5
mysql 5.0.51
Any idea what could be the problem?
thx,
mahdi
(Matthieu Aubry) #2
I would say that you have some special settings in your PHP installation. I can’t reproduce this bug on my machine.
Do you have ZLIB compression enabled? Do you have any other enabled setting that could be interesting or not so common ?
please check your phpinfo(); and let us know
(robocoder) #3
Based on mahdi1234’s settings (ticket 328), I suggested the following .htaccess changes:
php_value output_handler none php_flag register_globals off php_flag safe_mode off
(mahdi1234) #4
[quote=robocoder @ Dec 26 2008, 04:12 PM]Based on mahdi1234’s settings (ticket 328), I suggested the following .htaccess changes:
[/quote]
Thanks it works. I suggest to update http://piwik.org/docs/requirements/ with safe mode requirement.
cheers
(nikkilorens) #5
Greetings. I too had such problem. Thanks all for answers.
(Matthieu Aubry) #6
Everybody in this topic, did your problem come from the fact that safe_mode was enabled? Did you have to disable safe_mode to get Piwik working? Thanks for your details.
