Inconsistency between System Check and console diagnostics
Hello, My first message here. Well, I’m fine tuning my installed Matomo and found a kind of inconsistency between a check done from the GUI against the one done from command line.
In System Check, it says " Set up Cron - Managing processes via CLI not supported (optional) (Reasons: shell_exec is disabled)"
So, I read https://matomo.org/faq/troubleshooting/how-to-make-the-diagnostic-managing-processes-via-cli-to-display-ok/ and ran the related command from shell prompt as below:
$ sudo ./console diagnostics:run --all | grep -i "processes via cli"
Set up Cron - Managing processes via CLI: OK Ok
So, what is the right report?
Also, it leads to a side question: the control panel I’m using disabled a list of PHP functions including shell_exec and if I remove it from the list, it raises a warning indicating a security issue. Then, does the shell_exec is mandatory for Matomo (e.g. to schedule tasks through cron) or is it just an optional way?
Let me know.
Anyway, very clear and polished insights; I think I’ll rest from Google Analytics °O°
Hi @hilo
In my understanding:
Probably Matomo uses shell_exec to check the CRON is enabled or not… Then if shell_exec is disabled, Matomo could not check…
shell_exec seems to be not mandatory for Matomo, just used to check some settings, that’s why only a warning is raised, not an error…
OK, @heurteph-ei, thanks. So, do you know if these related cron jobs are described somewhere, to be able to configure them by hand?
Hi @hilo
AFAIK, the only CRON to be configured is:
OK :wink: So, not necessary to allow shell_exec. Thanks for the link.
