Hello all…
I am having a problem importing logs to my Motomo…
I use to import 2 sites with import_logs.py with the command:
python import_logs.py --idsite=24 --url=https://******* /apps/logs/apps/*00
the log format was :
LogFormat “%P %h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i””
Now they change the logformat to:
LogFormat “%P %h %{X-Forwarded-For}i %l %u %t “%r” %>s %b %D “%{Referer}i” “%{User-Agent}i””
Is there something I should change with the import_logs.py command?
Regards
