I use Google Analytics Importer (Matomo Plugin) to import my GA universal in matomo for wordpress.
When I run the import nothing happend and the task stop without error and say “killed: It looks like the import task has completed. If you haven’t done this yourself, your host probably doesn’t like long-running PHP processes. The import task will start again within an hour, so the import will continue. If import speed is still slow overall (check back in a day to see), see the user guide for more info and workarounds.”
But when I check back the next day nothing had changed.
Thank you in advance for any feedback,
El
