Hello there,
When im logged in to piwiks backend the images show just fine in the iframe widget on anohter page (im using the token code) but when i logout they disapear?
Is there i way this can be fixed? Please help.
Hello there,
Thanks for the reply, but the patch didn’t solve my problem…
Anyone else?
I am using the dashboard iframe with Piwik 1.12. The dashboard has the user’s token_auth, but the images being retreived for the goals overview widget does not use it as a parameter.
Is this still an open issue?
Anybody else seeing this?
I upgraded to Piwik 2.0-b2. Unfortunately, this has not solved the issue.
Also, I am seeing a couple display issues within the embedded dashboard.
Thanks for the reports!
I fixed the encoding in live widget at: Adding missing |raw to money metrics to avoid double encoding · matomo-org/matomo@abe8ba1 · GitHub
the other full screen menu bug will be fixed as part of: Regression: full screen embed dashboard shows Menu behind calendar · Issue #4234 · matomo-org/matomo · GitHub
Sparklines not loading: fixed in Fixes #4264 When embedding the custom dashboard using &token_auth, ap… · matomo-org/matomo@4f1128e · GitHub
if you find more please let me know
Awesome, thanks a lot matt!
