Since the Update to 0.8 i can’t embed iframes widgets to other sites anymore.
There is an example link under “widgets” in the main navi. This link is not working anymore. When I click on it, it just takes me to the login screen. (“Widgetize the full dashboard" --> "see example”).
The same thing is happening when i want to access it from external website with the piwik token.
/index.php?module=Widgetize&action=iframe&moduleToWidgetize=Dashboard&actionToWidgetize=index&idSite=1&period=week&date=yesterdaytoken_auth=XXXXXXXXXXX
This link just takes me to the login screen.
When I call the “normal” API with the piwik token it works just fine
/index.php?module=API&method=VisitsSummary.get&idSite=81&period=day&date=today&format=xml&token_auth=XXXXXXXX
Has there been made a change that I missed? Or can anyone reproduce this error?
Thanks alot.
Update:
In a second installation i just updated, the error does not appear. Does anyone have a clue how to fix it?
