this is my first questions in this forum, i have some question :
1.Can i store metric output to PHP variable ?
ex.
$request = new Piwik_API_Request(‘
method=UserSettings.getResolution
&idSite=7
&date=yesterday
&period=week
&format=HTML
&filter_limit=3
&token_auth=anonymous
$result = $request->process();
how to store metric output e.g. nb_visits in php variable?
Can i customize metric output?
thx for your help
matthieu
(Matthieu Aubry)
August 10, 2012, 1:22am
2
Thx matt for your advice
but, how to call in PHP?
when is use
echo $result; // call all metric
echo $result->nb_visits ??
echo $result[‘nb_visits’];
print only ‘a’
here’s my full code
define(‘PIWIK_INCLUDE_PATH’, realpath(‘piwik’));
define(‘PIWIK_USER_PATH’, realpath(‘piwik’));
define(‘PIWIK_ENABLE_DISPATCH’, false);
define(‘PIWIK_ENABLE_ERROR_HANDLER’, false);
define(‘PIWIK_ENABLE_SESSION_START’, false);
require_once PIWIK_INCLUDE_PATH . “/index.php”;
require_once PIWIK_INCLUDE_PATH . “/core/API/Request.php”;
Piwik_FrontController::getInstance()->init();
method= Actions.getPageUrl
&pageUrl=/index
&idSite=1
&date=today
&period=week
&format=PHP
&token_auth=sumsum
matthieu
(Matthieu Aubry)
August 11, 2012, 9:27am
6
if you do
$result = unserialize($result);
var_dump($result);
you can see the value of the variable and choose which value to use in the array
Wow, thank’s Matt,
you are my lifesaver
case closed
