I cannot install your piwik code in my blog because I cannot realize how to set up the idsite value; may ypu help me please?
Thank you.
Cypherinfo.
Thank you.
Cypherinfo.
Fetch your tracking code from Settings -> Websites and then scroll right until you see the link “Show tracking tags”.
For blogspot: I think you need to adjust the theme you’re using to embed the tracking code properly.
where I find the Settings -> Websites; do you mean after a local installation of piwik?
Blogspot is the google blog platform online; no a local installation.
Thank you.
Cypherinfo.
where I find the Settings → Websites; do you mean after a local installation of piwik?
Yes, login to your piwik installation. You find the link to Settings on the top right corner.
I’m aware of that.
do you mean I have to install piwik on my pc first; even if mine is an online blog?
What if I have a nokia n900 running debian linux?
Thank you.
Cypherinfo.
[quote=cypherinfo @ Sep 1 2010, 02:39 PM]Hello,
Thank you.
Cypherinfo.[/quote]
No, you have to install Piwik on a web host first, not locally.
