Is there a way to clear conversion history without having to delete the goal? I’ve been testing a landing page that I’m about to go live with but, I want to clear the conversion history before hand so I have accurate data to work with.
-Will
-Will
The easiest way for this is to delete the goal and create a new one with the same definition.
I’ll try it out…Thanks!
