High Traffic Site archiving not working :(
i am a developer and sysadmin and I am using piwik for about 3 months on a high traffic site.
In the last 3 days we had about 200.000 page impressions a day and the archive cronjob dosen’t work any more.
I tried it directly at the shell and get this error:
Archiving period = year for idsite = 1…
PHP Fatal error: Allowed memory size of 2122317824 bytes exhausted (tried to allocate 5 bytes) in /var/www/piwik/core/DataTable.php on line 969
Piwik is running on an extra server just for piwik with a single core xeon and 2 GB RAM, so I couldn’t give php more memory…
Seems to me, that the archiving-process has memory-leaks and isn’t optimized.
Any hints? Tried all the hints from the FAQs and the docs…
Thanks,
Jan
Well, 2122317824 bytes are just ~253 Mb - make sure you setup the memory limit for php and php cli to a higher value.
~Peter
memory_limit = 2048M -> in both CLI and apache php.ini
and I can see that the process for archiving is consuming all memory so that the server is swapping…
Well, 2122317824 bytes are 2024 MB, says google: http://www.google.com?q=2122317824+bytes+in+megabytes :wink:
Oh indeed, I used the “Bit”-Row for the calculation.
Well, that’s not good indeed - are you running Apache/Nginx/Lighttpd on the server?
I am running Apache, but want to switch to cherokee in the next weeks.
Unfortunately a known issue: Archiving Memory exhausted error - Archiving memory leaks · Issue #766 · matomo-org/matomo · GitHub
we will work on this problem in the next few months as more and more piwik users are reaching this problem
[quote=matt]
we will work on this problem in the next few months as more and more piwik users are reaching this problem[/quote]
I read this and I will debug the archive process to find a fix.
