Was only getting conternents and no brake down on map so attempted update β¦ Got this after update attempt getting these two errors and canni log in β¦ dont want to lose a years worth of analitics β¦ please help
β¦
There is an error. Please report the message (Piwik 2.0.3) and full backtrace in the Piwik forums (please do a Search first as it might have been reported already!).
Notice: Undefined index: force_ssl_login in /var/www/vhosts/*****/httpdocs/piwik/plugins/Login/Controller.php on line 494
Backtrace -->
#0 Piwik\Error::errorHandler(β¦) called at [/var/www/vhosts//httpdocs/piwik/plugins/Login/Controller.php:494]
#1 Piwik\Plugins\Login\Controller->checkForceSslLogin(β¦) called at [/var/www/vhosts/httpdocs/piwik/plugins/Login/Controller.php:78]
#2 Piwik\Plugins\Login\Controller->login(β¦) called at [/var/www/vhosts//httpdocs/piwik/plugins/Login/Controller.php:65]
#3 Piwik\Plugins\Login\Controller->index(β¦) called at [:]
#4 call_user_func_array(β¦) called at [/var/www/vhosts//httpdocs/piwik/core/FrontController.php:117]
#5 Piwik\FrontController->dispatch(β¦) called at [/var/www/vhosts/*****/httpdocs/piwik/index.php:62]
Notice: Undefined index: track_visits_inside_piwik_ui in /var/www/vhosts/*****httpdocs/piwik/core/Plugin/Controller.php on line 549
Backtrace -->
#0 Piwik\Error::errorHandler(β¦) called at [/var/www/vhosts//httpdocs/piwik/core/Plugin/Controller.php:549]
#1 Piwik\Plugin\Controller->setBasicVariablesView(β¦) called at [/var/www/vhosts//httpdocs/piwik/plugins/Login/Controller.php:115]
#2 Piwik\Plugins\Login\Controller->configureView(β¦) called at [/var/www/vhosts//httpdocs/piwik/plugins/Login/Controller.php:102]
#3 Piwik\Plugins\Login\Controller->login(β¦) called at [/var/www/vhosts//httpdocs/piwik/plugins/Login/Controller.php:65]
#4 Piwik\Plugins\Login\Controller->index(β¦) called at [:]
#5 call_user_func_array(β¦) called at [/var/www/vhosts//httpdocs/piwik/core/FrontController.php:117]
#6 Piwik\FrontController->dispatch(β¦) called at [/var/www/vhosts//httpdocs/piwik/index.php:62]
