Hi Friends,
I’m suddenly seeing this error on my dashboard, instead of the widgets (one for each widget):
ERROR: Failed to get data from API: SQLSTATE[42000]: Syntax error or access violation: 1286 Unknown storage engine ‘InnoDB’
And there’s a less specific error under System Check. I’m not sure if it refers to the same thing, or something different:
Required PHP configuration (php.ini)
I strongly suspect my stupid host has made some change, since I have not made any changes. Although I’m still using version 3.5.1, and maybe I just need to upgrade?
Could someone point me in the general direction, to start to fix this?
Thanks for your help
