Hello!
Can you please send your full Piwik DB backup using 0.6.4 at matt atttt piwik.org ? please add problem descrpition and link to this post. I’ll take a look and try and fix the issue! thx
[quote=matthieu @ Jul 23 2010, 06:33 AM]Hello!
Can you please send your full Piwik DB backup using 0.6.4 at matt atttt piwik.org ? please add problem descrpition and link to this post. I’ll take a look and try and fix the issue! thx[/quote]
It is nearly 600MB. Can you please be more specific or suggest potential issues. I am fairly good with mysql/php and if you give me a direction or idea on what you are looking for I can probably help.
you can delete all piwik_archive_* tables it shoudl be much smaller (I don’t mind large db…). I can’t help much I need to debug through the code to understand what triggers the failure case.
