fastlane
(Fast Lane)
1
Running 0.6.3…
if I run the stats builder I get (this was working for weeks and suddenly stopped):
-bash-3.2$ /home/user/public_html/stats/misc/cron/archive.sh
Starting Piwik archiving…
Archiving period = day for idsite = 1…
Fatal error: Cannot use object of type Piwik_DataTable_Row as array in /home/user/public_html/stats/plugins/Actions/Actions.php on line 414
or if I log into piwik I get (in the last visits box):
and in all the other boxes:
Fatal error: Maximum execution time of 30 seconds exceeded
matthieu
(Matthieu Aubry)
2
are you sure you’re running 0.6.3 ? this looks the same as an old bug we fixed recently.
fastlane
(Fast Lane)
3
[quote=matthieu @ Jul 19 2010, 09:09 AM) <{POST_SNAPBACK}>
Yep. I saw that bug report and tried the fixes (they were already in the code]version $Id: Actions.php 2264 2010-06-03 16:53:43Z vipsoft $[/quote]
I verified this is the same as the main download. I have always had this version (only installed 2 weeks ago).
fastlane
(Fast Lane)
4
[quote=Fast Lane @ Jul 19 2010, 04:09 PM]Yep. I saw that bug report and tried the fixes (they were already in the code).
I verified this is the same as the main download. I have always had this version (only installed 2 weeks ago).[/quote]
Any ideas? I can provide more info if you need it.
matthieu
(Matthieu Aubry)
5
please try a full reinstall of http://builds.piwik.org/piwik-0.6.4-rc1.zip
and if you still see that bug let us know
fastlane
(Fast Lane)
6
Uploaded the file you gave me…
Now piwik will not even load:
The merged asset : couldn’t be parsed for getting the hashcode.
I get the above if I even try to view piwik from the browser.
when I run the archive script (sh /home/user/public_html/stats/misc/cron/archive.sh) I still get:
Fatal error: Cannot use object of type Piwik_DataTable_Row as array in /home/user/public_html/stats/plugins/Actions/Actions.php on line 415
help!
I also get the hashcode message:
<P>The merged asset : couldn't be parsed for getting the hashcode.</P><FONT color=#888888>Backtrace:
<PRE>#0 /users/jmp/www/piwik_test/core/AssetManager.php(377): Piwik_AssetManager::getMergedAssetHash('css') #1 /users/jmp/www/piwik_test/core/AssetManager.php(424): Piwik_AssetManager::removeMergedAsset('css') #2 /users/jmp/www/piwik_test/plugins/Installation/Controller.php(76): Piwik_AssetManager::removeMergedAssets() #3 /users/jmp/www/piwik_test/plugins/Installation/Installation.php(72): Piwik_Installation_Controller->welcome('The configurati...') #4 [internal function]: Piwik_Installation->dispatch(Object(Piwik_Event_Notification)) #5 /users/jmp/www/piwik_test/libs/Event/Dispatcher.php(213): call_user_func_array(Array, Array) #6 /users/jmp/www/piwik_test/core/PluginsManager.php(389): Event_Dispatcher->addObserver(Array, 'FrontController...') #7 /users/jmp/www/piwik_test/core/PluginsManager.php(272): Piwik_PluginsManager->addPluginObservers(Object(Piwik_Installation)) #8 /users/jmp/www/piwik_test/core/PluginsManager.php(180): Piwik_PluginsManager->reloadPlugins() #9 /users/jmp/www/piwik_test/core/FrontController.php(208): Piwik_PluginsManager->loadPlugins(Array) #10 /users/jmp/www/piwik_test/index.php(58): Piwik_FrontController->init() #11 {main}</FONT>
matthieu
(Matthieu Aubry)
8
Ok sorry you just hit a new bug with the he merged asset : couldn’t be parsed for getting the hashcode
I tried and fixed it, can you please try again with this new RC: http://builds.piwik.org/piwik-0.6.4-rc4.zip ?
[quote=matthieu @ Jul 21 2010, 11:11 AM]Ok sorry you just hit a new bug with the he merged asset : couldn’t be parsed for getting the hashcode
I tried and fixed it, can you please try again with this new RC: builds.piwik.org/piwik-0.6.4-rc4.zip ?[/quote]
it´s a pity, but I get the same error with rc4.
flow
(flow)
10
Hi all,
when I upgraded from 0.6.3 to 0.6.4 (both methods) I receive following error message:
Backtrace:
#0 /…/piwik/core/AssetManager.php(386): Piwik_AssetManager::getMergedAssetHash(‘css’)
#1 /…/piwik/core/AssetManager.php(433): Piwik_AssetManager::removeMergedAsset(‘css’)
#2 /…/piwik/plugins/CoreUpdater/CoreUpdater.php(64): Piwik_AssetManager::removeMergedAssets()
#3 /…/piwik/libs/Event/Dispatcher.php(284): Piwik_CoreUpdater->dispatch(Object(Piwik_Event_Notification))
#4 /…/piwik/core/PluginsManager.php(532): Event_Dispatcher->postNotification(Array, Array)
#5 /…/piwik/core/FrontController.php(227): Piwik_PostEvent(Object(Piwik_Event_Notification), true, false)
#6 /…/piwik/index.php(58): Piwik_FrontController->init(‘FrontController…’)
#7 {main}
What is the issue here and how to solve it? Many thanks for any help/hints!
cheers
flo.
watzhh
(watzhh)
12
[quote=matthieu @ Jul 21 2010, 10:11 AM]Ok sorry you just hit a new bug with the he merged asset : couldn’t be parsed for getting the hashcode
Got the same error using 0.6.4-rc4
My “Seems to work for me but use on your own risk” Solution:
In AssetManager.php function getMergedAssetHash the return value of glob is used without check for false as a return value - and it returned false.
Inserted this after the glob() call treating false like no file found and it seems to work:
if($matchingFiles === false) return false;
matthieu
(Matthieu Aubry)
13
ok that’s a new bug - can you please try the following change to the files: http://dev.piwik.org/trac/changeset/2619
Delete files in tmp/assets (it should be there and created, is it?)
Then visit your Piwik UI which should take a few seconds to load.
Then each refresh of PIwik should be fast and you shouldn’t see the error message.
Let me know if it works thx
seems to be fixed. I saw the changeset in trac.
matthieu
(Matthieu Aubry)
15
Thanks for the patch, I committed it. Let me know if it works for you.
That works wonderfull, THX.
that didnt work
matthieu
(Matthieu Aubry)
18
fastlane
(Fast Lane)
19
On the original topic, after upgrading to 0.6.4 and applying the hash fix, I still get the same errors as in post #1.
…at the shell prompt (-bash-3.2$ sh /home/user/public_html/stats/misc/cron/archive.sh)
Fatal error: Cannot use object of type Piwik_DataTable_Row as array in /home/user/public_html/stats/plugins/Actions/Actions.php on line 480
Archiving period = week for idsite = 1…
Archiving period = year for idsite = 1…
Archiving for idsite = 1 done!
Piwik archiving finished.
