HELP! Please
I just installed Piwik to my server, it told me that the installation was successful, but i keep getting the following Warning message fo a lot of the plugins. Please help with this. I have check on line 255 in my Mysqli.php file and the only thing there is “);”. I dont know what to do, please help me get this fixed asap. Thank You
[b]
Warning: mysqli_stmt::bind_result() [mysqli-stmt.bind-result]: Server returned unknown type 246. Probably your client library is incompatible with the server version you use! in /nfs/c04/h02/mnt/62057/domains/emagsearchnfind.com/html/analytics/libs/Zend/Db/Statement/Mysqli.php on line 255
[/b]
I think that means the mysqli extension needs to be rebuilt with a client library that matches your server. Ask your hosting provider to update it. This requires system privileges that you probably don’t have.
