Hello
I’m trying to log in and I get the following error, can you help me?
Error : The form security failed because of invalid origin. If you previously connected using HTTPS, please ensure you are connecting over a secure (SSL/TLS) connection and try again.
my matomo_system_check
<details>
<summary>Click to view System Check</summary>
Mandatory checks
Versão do PHP >= 7.2.5:
7.4.32
PDO extensão:
PDO\MYSQL extensão:
MYSQLI extensão:
Outras extensões requeridas:
zlib json filter hash session
Funções requeridas:
debug_backtrace eval hash gzcompress gzuncompress pack
Configuração PHP requerida (php.ini):
session.auto_start = 0 max_execution_time = 0 OR = -1 OR >= 30
Diretórios com permissão de escrita:
$DOC_ROOT/tmp $DOC_ROOT/tmp/assets $DOC_ROOT/tmp/cache $DOC_ROOT/tmp/climulti $DOC_ROOT/tmp/latest $DOC_ROOT/tmp/logs $DOC_ROOT/tmp/sessions $DOC_ROOT/tmp/tcpdf $DOC_ROOT/tmp/templates_c $DOC_ROOT/config
Optional checks
Integridade dos arquivos:
Binário de 64 bits do PHP:
Status do Rastreador:
Limite de Memória:
1024M
Fuso horário:
Abre URL:
curl
PageSpeed desativado:
GD > 2.x + Freetype (gráficos):
outras extensões:
json libxml dom SimpleXML openssl
Outras funções:
shell_exec set_time_limit mail parse_ini_file glob gzopen md5_file
Sistema de arquivos:
Configurar o Cron - Gerenciar processos via CLI:
OK
Atualização por HTTPS:
Rastreador Javascript gravável ("/matomo.js"):
Informational results
Matomo Version:
4.12.3
PHP_OS:
Linux
PHP SAPI:
litespeed
PHP Timezone:
UTC
PHP Time:
1668434465
PHP Datetime:
2022-11-14 14:01:05
PHP INI max_execution_time:
1200
PHP INI post_max_size:
100M
PHP INI max_input_vars:
1000
PHP INI zlib.output_compression:
1
Curl Version:
7.86.0, OpenSSL/1.1.1q
Suhosin Installed:
0
Server Info:
LiteSpeed
User Agent:
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36
Browser Language:
pt-br,pt
</details>
