Help adjusting Matomo
Hi, I am having few suggestions on the system check to adjust. They are:
  • Set up Cron (faster report-loading)
  • Database abilities
Regarding the Cron, I set 00 in minutes and what to insert in other fields like hours etc? The support documentation says leave them as blank, but you cannot. They are mandatory fields. Can you guide me what to put in the rest of the fields?
Regarding data abilities, how to grant FILE privilege to MySQL server on cPanel? I granted all privileges when creating Matomo and there was no FILE as selection. Also, I cannot import Google Analytics data into Matomo because of this FILE privilege. It is killing the process.
Thanks
