i’ve got a problem with my graph generation. i see in den last visited log that about 100 visitors. but in the graph they are not showing.
as you can see it has worked bevor but now it doesent work anymore.
is there a solution for this?
best
best
In Settings > General Settings > check that “Enable browser trigger archiving” is set to YES.
Otherwise make sure you setup the cron job correctly as per How to Set up Auto-Archiving of Your Reports - Analytics Platform - Matomo
