I use PIWIK to track the clicks on my amazon affiliate links in my blog.
I set a goal to track the outgoing clicks and everthing worked fine.
Now I replaced my amazon affiliate links with a .php file including a redirect with my amazon affiliate link. So my visitors click on myblog.com/productname.php and will be redirected to my amazon link.
Since then my goal tracking does not work anymore. Of course I created a new goal with the .php file as a url in it.
I also tried “external link” and “internal website” as goal.
Funny but I have exactly the same problem. I use .com/visitid123 to redirect visitors to my affiliate links and it seems that piwik doesnt track goals. I tried many configurations but without any success. How to solve this issue?
then in PIWIK, created a manual goal “1” with following selected: “Click on a Link to an external website” and “Allow Goal to be converted more than once per visit”.
I click on those links, and PIWIK does not track them. What am I doing wrong?
UPDATE: Everything works great now. My mistake, I was using wrong Goal ID. Why Goal ID is not displayed while creating a goal? It can be found only when Editing Goals. I think this is confusing for less technical people.
and chose “Click on a Link to an external website” and set the URL to “is exact” mywebsite.xx/redirect-file.php. ID of the goal is 2.
It still doesn’t work
It still doesn’t work :([/quote]
I presume you left “when visitor triggers” on. You must choose “Manually” under the “Goal is triggered”. So, Edit ID 2 goal, set to manually, update and it should work perfectly.
BTW, Piwik is absolutely awesome! Loving it, especially the “Visitors Log”, it shows so much of valuable information. Google Analytics cannot compare to this. Great job! Thank you Piwik Developers! Keep up the good work.
I presume you left “when visitor triggers” on. You must choose “Manually” under the “Goal is triggered”. So, Edit ID 2 goal, set to manually, update and it should work perfectly.[/quote]
Hello everyone,
I had a similar problem, and that solution with the “Force a Click on a Link to be Recorded as an Outlink” worked nicely for me, I’ve added the ‘piwik_link’ class to links and all goals are now counting Thank you so much!
