Hi that’s maybe a simple thing to do but I cannot think of a way so far…
I got a site that uses a catalog with artworks.
on each artwork page there are 5 images for that specific artwork, the 2 of which exist in a different directory “/images/artwork/…” than the rest 3 which come from another directory “/thumbs/…” which exists outside “images” directory, elsewhere.
Those directory paths have nothing in common so that I can use that as the “contains” in a goal, in order to create a goal named “Viewing Artworks” using “Download a file”.
I have so far succeeded in creating a goal with the following settings:
Goal Name: Viewing Artworks
Goal is triggered: when visitor >> Download a file
where the filename: contains >> "images/artwork"
Allow multiple conversions per visit: Allow Goal to be converted more than once per visit
So, of course I can create another goal for the other directory “/thumbs/…”, but is there a way to include both in 1 goal so that the stats for viewing artworks comes from all those images ?
I will be thankful to know if someone can help with this
cheers
EDIT: //
the only solution I can see so far is to make the goal so that it “contains” >> ".jpg"
not so smart, but hope there is a better solution to this
