Our websites are accessed externally and internally (with an IP from the local network range).
GeoIp is installed and enabled.
Despite having set enable_language_to_country_guess=0, the geolocation information for users from the local network is set based on their browser language and therefore totally wrong.
This seems to happen in Common::extractCountryCodeFromBrowserLanguage and I’ve got the feeling that this function does not respect the config value correctly.
public static function extractCountryCodeFromBrowserLanguage($browserLanguage, $validCountries, $enableLanguageToCountryGuess)
/** @var LanguageDataProvider $dataProvider */
$dataProvider = StaticContainer::get('Piwik\Intl\Data\Provider\LanguageDataProvider');
$langToCountry = $dataProvider->getLanguageToCountryList();
if ($enableLanguageToCountryGuess) {
if (preg_match('/^([a-z]{2,3})(?:,|;|$)/', $browserLanguage, $matches)) {
// match language (without region) to infer the country of origin
if (array_key_exists($matches[1], $langToCountry)) {
return $langToCountry[$matches[1]];
// the following code should run only if enableLanguageToCountryGuess is enabled
if (!empty($validCountries) && preg_match_all('/[-]([a-z]{2})/', $browserLanguage, $matches, PREG_SET_ORDER)) {
foreach ($matches as $parts) {
// match location; we don't make any inferences from the language
if (array_key_exists($parts[1], $validCountries)) {
return $parts[1];
return self::LANGUAGE_CODE_INVALID;
I would prefer having an “unknown” country to having a wrong one (US, UK, DE…).
Is there any way to achieve this?
