Hello!
I’m looking into the location tracking options for Matomo. There is two options for reading GeoIP databases.
Using PHP API to read the database.
Using HTTP-server module.
The documentation says option 2 is faster and more accurate. But that solution only works with normal browser tracking. Then i saw there is an optional C extension for the PHP API used in option 1 recommended for high traffic instances. Is this solution equally good as solution 2 or is that still faster? Solution 1 with the C extension seems more simple and less complex than solution 2.
Thanks for the answer! Do you know if the http-module (solution 2) always is faster than 1 with the C extension? I read in this article that there was no performance metrics for the Nginx module. Is that still the case?
I don’t think that the http-module will be faster (or slower) than the PHP module (with C module) as after all they are doing the exact same lookup, just in one case Matomo does it and in the other one the webserver does it and Matomo trusts its output.
I don’t think anyone on the Matomo team is using the nginx module, but that doesn’t mean much apart from that you probably need to do some testing yourself.
