I have added GEOIP to my install of Piwik 1.0 running on a LAMP server.
When I run the updaterows script it updates the first entry in the database of each 1000.
The script runs a query that gets only 1000 entries and is supposed to update each one then start at 1000 and get the next 1000 entries.
Has anyone else seen this problem?
Thank you, I came up with the same resolution, and just overlooked that one comment.
