General_ExceptionConfigurationFileNotFound Installation Error
#1
HI ,
I just downloaded and uploaded the new version of piwik in my server , and when I go in my browser and point to the URL where my folder is I get an error :
This is a new install I have not installed piwik before
could you help me whats the problem?
Thanks
(Matthieu Aubry) #2
could you please try this version? http://builds.piwik.org/piwik-2.5.0-b3.zip
#3
ok i will try it now
#4
still getting the same error even with the one you gave me ??
#5
could you help me solve the problem?
(Matthieu Aubry) #6
Can you change the permission of your config/config.ini.php to CHMOD 777 ? This may fix the problem that the file is not readable.
#7
I dont have that file in config/ folder
(Matthieu Aubry) #8
Check that your config/ folder itself has permission 755 or 777 maybe this would help?
#9
it has 755 permission
#10
I changged it to 777 and still same error ?>
#11
does the script work?
#12
I fixed it , it was a permission problem , now I have installed it and it works , I don’t see any data yet? how long does it take to show some data
