I’ve just upgraded from 2.8.0 to 2.9.1.
We had a number of problems upgrading our test instances, and the only way we seemed to be able to reliably perform the upgrade was to manually install each of the intermediate versions, checking for any database upgrades after doing each version by visiting the Piwik admin console homepage.
However, we’ve just performed an upgrade on our live instance in this way and have another problem. We weren’t seeing any visits coming through. In the PHP log files there are loads of these:
[23-Dec-2014 12:11:41 UTC] Error in Piwik (tracker): Error query: SQLSTATE[HY000]: General error: 1364 Field ‘config_browser_engine’ doesn’t have a default value In query: INSERT INTO log_visit (idvisitor, config_id, location_ip, config_flash, config_gears, config_java, config_pdf, config_director, config_cookie, config_browser_version, idsite, config_os, config_quicktime, config_realplayer, visitor_days_since_last, location_provider, visitor_localtime, visit_total_events, config_silverlight, config_windowsmedia, config_resolution, config_browser_name, location_browser_lang, location_country, visit_last_action_time, visit_total_time, visit_first_action_time, visit_goal_buyer, visit_goal_converted, visitor_days_since_first, visitor_days_since_order, visit_total_searches, visit_total_actions, referer_keyword, referer_name, referer_type, visit_exit_idaction_url, visit_exit_idaction_name, visitor_returning, visitor_count_visits, visit_entry_idaction_name, visit_entry_idaction_url, referer_url) VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?) Parameters: array ( 0 => ‘·Ì°†(’, 1 => ‘°»»à&ôÚ’, 2 => ’ ‡Y’, 3 => 1, 4 => 0, 5 => 1, 6 => 1, 7 => 1, 8 => 1, 9 => ‘32.0’, 10 => 4, 11 => ‘WI7’, 12 => 0, 13 => 0, 14 => ‘0’, 15 => ‘derbyad.net’, 16 => ‘12:11:41’, 17 => 0, 18 => 1, 19 => 0, 20 => ‘1280x1024’, 21 => ‘CH’, 22 => ‘en-gb’, 23 => ‘gb’, 24 => ‘2014-12-23 12:11:41’, 25 => 0, 26 => ‘2014-12-23 12:11:41’, 27 => 0, 28 => 0, 29 => ‘0’, 30 => 0, 31 => 0, 32 => 1, 33 => ‘’, 34 => ‘’, 35 => 1, 36 => 459, 37 => 457, 38 => 0, 39 => 1, 40 => 457, 41 => 459, 42 => ‘’, )
As this is our live server, I’ve gone in and added a default value of an empty string into the config_browser_engine column within the log_visit table. This seems to have fixed the problem.
However:
- Does this error indicate an underlying problem with some other part of Piwik?
- Was this the right thing to do?
- Should this column have a default value, or, I was wondering whether perhaps only the earlier versions needed a default value, and that the code now should be able to work without a default - In which case has a database upgrade failed? These instructions to force another database upgrade After the update, I get sql errors, I would like to try the update again. How do I force Piwik to re-upgrade the database from a past version? - Analytics Platform - Matomo don’t seem to be correct any more, as there’s no piwik_option table.
Help!
Thanks,
Adam.
