I’m trying to delete some logs of a website using GDPR Tool, but I’m having a Issue when query exceeds 400 records. Matomo returns an error message saying “Please specify a value for ‘visits’”.
If query is under 400 records everything is fine.
Setup:
Matomo On-Premises 3.14.0
PHP 7.0.33
Windows Server 2019
The GDPR tools are using the normal API to make requests, so can you open your browsers developer tools and check if the request in the network tab (when you click on delete or export) looks correct.
