Is it possible to filter the visitors graph based on a custom variable from the tracker? I want to show an evolution graph of all the visits with a 70 value in the first custom variable slot. I tried this call
They will be processed the first time you ask for and then cached. However it will be pre-processed by archiving. You can do so, see [Segments] in the file config/global.ini.php for more info
Happy New Year! If you are still using Piwik and interested in the awesome new feature of “Creating a Custom Segment in Piwik and apply to reports in Real time!” we need YOUR help, with a little or big donation at: http://crowdfunding.piwik.org/custom-segments-editor/
This will allow to dynamically add or edit, a new set of rules for example “Show all visitors from USA and using Firefox and using Google”. This will be done via a simple to use interface. See screenshots and more info here: http://crowdfunding.piwik.org/custom-segments-editor/
We are crowd funding the future of Piwik and this feature in particular. With your help we can do it.
