Filter data by users from Korea
I am currently setting up some segments for my Matomo account. I would like to set up segments for the countries that are most important to my client. I was able to create these segments for Austria, Germany and many other countries without any difficulty using the country function.
Strangely, this process does not work for Korea. I can’t even see Korea among the possible options for countries when I try to create a segment based on countries. However, in Matomo I can see that users from Korea are visiting my website.
Does Matomo not allow to filter the data by users from Korea
or does the problem lie somewhere else?
Thank you in advance!
Hi @Alewa
Why do you write « I can’t even see Korea among the possible options for countries when I try to create a segment based on countries »? do you mean the suggestions the UI provides? As this is a limited list, not all values are displayed. You can type your own desired value (and don’t forget to try the segment thanks to the appropriate button)
