I’m trying to export a segmented dataset containing information on visits by device type within a pageUrl segment.
When looking at the Matomo dashboard, I’m seeing the data just fine. But when exporting the data to JSON, all it shows is []. I’ve attempted other types like XML or CSV, but none of them contain the data.
If I try removing the segment and then export, then I’m getting the JSON code just fine.
I’m new to Matomo, so I’m unsure if this is a bug or if I’m doing something wrong, but I’m assuming it’s a bug since the data shows correctly in Matomo itself, but not in the export.
Hello!
I am experiencing the same problem. I try to export a segmented visitor’s report but it does not work.
“No data available” is all I get in the Excel sheet. The exported file is named index(#).php. I will report this as a bug as well.
Best regards,
E
Great that you are already working on fixing this problem! We don’t have any testinstallation and we dare not test in our production environment. But I trust you and hope it will be included in the next update of Matomo. Something to look forward to! Big thanx!!
