Hello Piwik Gurus,
I have a problem regarding to export operations. I can not export more than 500 and if I try server gives memory allocation errors so export on Piwik page is obviously resource consuming.
There is also a bug I realized which is related to pageing on reports.
If I download the first page with 20 rows for example I got the 20 rows. But if I switch to the second page and export from the second page, it still exports only the first 20 rows which is shown in first page.
So, I need an advanced report exporter, it could be that it will only export the datas from maysql directly by direct mysql queries.
I can also get most used queries and use them to get the excels from the phpmyadmin.
I want to know if any one of you has a solution for that already?
Cheers
