ok yes this is hard to diagnose, others had issues using 5.2.x php and by going to 5.3.3 fixed things i know yours is close but trying 5.3.3 could that be a quick painless fix here?
Never heard of PHP 5.2.x issues with Piwik – so this will my next step.
I think we will update to PHP 5.5.7.
Our Apache log shows two exception faults for each archive.php attempt.
What errors exactly are you getting?
Good news, we’ve fixed this bug: https://github.com/piwik/piwik/commit/23a1c9d680a2409c182977cc02ebf1c00d414cd0
can you try apply the patch and confirm whether all issues are fixed during archiving and this error does not show anymore?
i have added this patch and i can confirm, all works. Website, that showed error is now archived properly and data is shown.
Thanks
Thanks for the patch!
Archiving works again, but still exits with the 2 errors I mentioned.
Piwik’s archive.log:
[size=x-small]INFO [2014-01-09 13:31:05] [972cd] SUMMARY OF ERRORS
INFO [2014-01-09 13:31:05] [972cd] Error: Got invalid response from API request: mysite.de. Response was 'curl_exec: Empty reply from server’
INFO [2014-01-09 13:31:05] [972cd] 2 total errors during this script execution, please investigate and try and fix these errors
INFO [2014-01-09 13:31:05] [972cd] ERROR: 2 total errors during this script execution, please investigate and try and fix these errors. First error was: Got invalid response from API request: mysite.de. Response was ‘curl_exec: Empty reply from server’[/size]
Apache Log:
[size=x-small]
[Thu Jan 09 13:30:41 2014] [notice] child pid 4373 exit signal Segmentation fault (11)
[Thu Jan 09 13:30:56 2014] [notice] child pid 4384 exit signal Segmentation fault (11)
[/size]
Me too, getting errors:
$ sudo -u www-data /usr/bin/php5 /mydir/piwik/misc/cron/archive.php --url=http://it.mysite.org/piwik/ --force-all-websites --force-all-periods
<td bgc INFO [2014-01-09 14:21:00] [7e9a5] WARNING: Empty or invalid response '' for website id 1, Time elapsed: 5081.622s, skipping
[sudo] password for user:
INFO [2014-01-09 12:56:18] [7e9a5] ---------------------------
INFO [2014-01-09 12:56:18] [7e9a5] INIT
INFO [2014-01-09 12:56:18] [7e9a5] Querying Piwik API at: http://it.mysite.org/piwik/index.php
INFO [2014-01-09 12:56:18] [7e9a5] Running Piwik 2.0.2 as Super User: user
INFO [2014-01-09 12:56:18] [7e9a5] NOTES
INFO [2014-01-09 12:56:18] [7e9a5] - Reports for today will be processed at most every 82800 seconds. You can change this value in Piwik UI > Settings > General Settings.
INFO [2014-01-09 12:56:18] [7e9a5] - Reports for the current week/month/year will be refreshed at most every 3600 seconds.
INFO [2014-01-09 12:56:18] [7e9a5] - Archiving was last executed without error 19 giorni 10 ore ago
INFO [2014-01-09 12:56:18] [7e9a5] - Will process all 14 websites
INFO [2014-01-09 12:56:18] [7e9a5] START
INFO [2014-01-09 14:21:00] [7e9a5] ERROR: Got invalid response from API request: http://it.mysite.org/piwik/index.php?module=API&method=VisitsSummary.getVisits&idSite=1&period=day&date=last520&format=php&token_auth=6862472f689dfbae97a714f8bf274219&trigger=archivephp. Response was '
(I didn’t create the tests/PHPUnit/Core/DataTableTest.php file which I hadn’t, I only created/updated the first 3 files in the given commit)
( ! ) Fatal error: Allowed memory size of 4294967296 bytes exhausted (tried to allocate 72 bytes) in /var/wwwc/piwik/core/DataTable.php on line 1317 Call Stack # Time Memory Function Location 1 0.0000 226272 {main}( ) ../index.php:0 2 0.0471 2795216 Piwik\FrontController->dispatch( ) ../index.php:71 3 0.0515 3032656 call_user_func_array ( ) ../FrontController.php:117 4 0.0515 3032824 Piwik\Plugins\API\Controller->index( ) ../FrontController.php:117 5 0.0522 3036408 Piwik\API\Request->process( ) ../Controller.php:34 6 0.0536 3061776 Piwik\API\Proxy->call( ) ../Request.php:220 7 0.0738 3137696 call_user_func_array ( ) ../Proxy.php:212 8 0.0738 3138312 Piwik\Plugins\VisitsSummary\API->getVisits( ) ../Proxy.php:212 9 0.0738 3138424 Piwik\Plugins\VisitsSummary\API->getNumeric( ) ../API.php:118 10 0.1097 3940008
Excuse me, spurius characters had been inserted: the call stack was:
Response was '<br />
<font size='1'><table class='xdebug-error xe-fatal-error' dir='ltr' border='1' cellspacing='0' cellpadding='1'>
<tr><th align='left' bgcolor='#f57900' colspan="5"><span style='background-color: #cc0000; color: #fce94f; font-size: x-large;'>( ! )</span> Fatal error: Allowed memory size of 4294967296 bytes exhausted (tried to allocate 72 bytes) in /var/wwwc/piwik/core/DataTable.php on line <i>1317</i></th></tr>
<tr><th align='left' bgcolor='#e9b96e' colspan='5'>Call Stack</th></tr>
<tr><th align='center' bgcolor='#eeeeec'>#</th><th align='left' bgcolor='#eeeeec'>Time</th><th align='left' bgcolor='#eeeeec'>Memory</th><th align='left' bgcolor='#eeeeec'>Function</th><th align='left' bgcolor='#eeeeec'>Location</th></tr>
<tr><td bgcolor='#eeeeec' align='center'>1</td><td bgcolor='#eeeeec' align='center'>0.0000</td><td bgcolor='#eeeeec' align='right'>226272</td><td bgcolor='#eeeeec'>{main}( )</td><td title='/var/wwwc/piwik/index.php' bgcolor='#eeeeec'>../index.php<b>:</b>0</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>2</td><td bgcolor='#eeeeec' align='center'>0.0471</td><td bgcolor='#eeeeec' align='right'>2795216</td><td bgcolor='#eeeeec'>Piwik\FrontController->dispatch( )</td><td title='/var/wwwc/piwik/index.php' bgcolor='#eeeeec'>../index.php<b>:</b>71</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>3</td><td bgcolor='#eeeeec' align='center'>0.0515</td><td bgcolor='#eeeeec' align='right'>3032656</td><td bgcolor='#eeeeec'><a href='http://www.php.net/call_user_func_array' target='_new'>call_user_func_array</a>
( )</td><td title='/var/wwwc/piwik/core/FrontController.php' bgcolor='#eeeeec'>../FrontController.php<b>:</b>117</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>4</td><td bgcolor='#eeeeec' align='center'>0.0515</td><td bgcolor='#eeeeec' align='right'>3032824</td><td bgcolor='#eeeeec'>Piwik\Plugins\API\Controller->index( )</td><td title='/var/wwwc/piwik/core/FrontController.php' bgcolor='#eeeeec'>../FrontController.php<b>:</b>117</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>5</td><td bgcolor='#eeeeec' align='center'>0.0522</td><td bgcolor='#eeeeec' align='right'>3036408</td><td bgcolor='#eeeeec'>Piwik\API\Request->process( )</td><td title='/var/wwwc/piwik/plugins/API/Controller.php' bgcolor='#eeeeec'>../Controller.php<b>:</b>34</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>6</td><td bgcolor='#eeeeec' align='center'>0.0536</td><td bgcolor='#eeeeec' align='right'>3061776</td><td bgcolor='#eeeeec'>Piwik\API\Proxy->call( )</td><td title='/var/wwwc/piwik/core/API/Request.php' bgcolor='#eeeeec'>../Request.php<b>:</b>220</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>7</td><td bgcolor='#eeeeec' align='center'>0.0738</td><td bgcolor='#eeeeec' align='right'>3137696</td><td bgcolor='#eeeeec'><a href='http://www.php.net/call_user_func_array' target='_new'>call_user_func_array</a>
( )</td><td title='/var/wwwc/piwik/core/API/Proxy.php' bgcolor='#eeeeec'>../Proxy.php<b>:</b>212</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>8</td><td bgcolor='#eeeeec' align='center'>0.0738</td><td bgcolor='#eeeeec' align='right'>3138312</td><td bgcolor='#eeeeec'>Piwik\Plugins\VisitsSummary\API->getVisits( )</td><td title='/var/wwwc/piwik/core/API/Proxy.php' bgcolor='#eeeeec'>../Proxy.php<b>:</b>212</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>9</td><td bgcolor='#eeeeec' align='center'>0.0738</td><td bgcolor='#eeeeec' align='right'>3138424</td><td bgcolor='#eeeeec'>Piwik\Plugins\VisitsSummary\API->getNumeric( )</td><td title='/var/wwwc/piwik/plugins/VisitsSummary/API.php' bgcolor='#eeeeec'>../API.php<b>:</b>118</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>10</td><td bgcolor='#eeeeec' align='center'>0.1097</td><td bgcolor='#eeeeec' align='right'>3940008</td><td>
The error with another site with more visits than the previous one. It seems like errors are recursive
Call Stack
10 0.1097 3940008
( ! ) Fatal error: Allowed memory size of 4294967296 bytes exhausted (tried to allocate 72 bytes) in /var/wwwc/piwik/core/DataTable/Row.php on line 80
Call Stack
2 0.0766 2793968 Piwik\FrontController->dispatch( ) ../index.php:71
3 0.0798 2901056 call_user_func_array ( ) ../FrontController.php:117
4 0.0798 2901224 Piwik\Plugins\API\Controller->index( ) ../FrontController.php:117
5 0.0805 2904808 Piwik\API\Request->process( ) ../Controller.php:34
6 0.0817 2930184 Piwik\API\Proxy->call( ) ../Request.php:220
7 0.0831 2958128 call_user_func_array ( ) ../Proxy.php:212
8 0.0831 2958744 Piwik\Plugins\VisitsSummary\API->getVisits( ) ../Proxy.php:212
9 0.0831 2958856 Piwik\Plugins\VisitsSummary\API->getNumeric( ) ../API.php:118
10 0.1130 3355816
Call Stack
Here is the html, see it in a browser:
<tr><td bgcolor='#eeeeec' align='center'>10</td><td bgcolor='#eeeeec' align='center'>0.1097</td><td bgcolor='#eeeeec' align='right'>3940008</td><td bgc
Error: Got invalid response from API request: http://it.cathopedia.org/piwik/index.php?module=API&method=VisitsSummary.getVisits&idSite=11&period=day&date=last520&format=php&token_auth=6862472f689dfbae97a714f8bf274219&trigger=archivephp. Response was '<br />
<tr><th align='left' bgcolor='#f57900' colspan="5"><span style='background-color: #cc0000; color: #fce94f; font-size: x-large;'>( ! )</span> Fatal error: Allowed memory size of 4294967296 bytes exhausted (tried to allocate 72 bytes) in /var/wwwc/piwik/core/DataTable/Row.php on line <i>80</i></th></tr>
<tr><td bgcolor='#eeeeec' align='center'>2</td><td bgcolor='#eeeeec' align='center'>0.0766</td><td bgcolor='#eeeeec' align='right'>2793968</td><td bgcolor='#eeeeec'>Piwik\FrontController->dispatch( )</td><td title='/var/wwwc/piwik/index.php' bgcolor='#eeeeec'>../index.php<b>:</b>71</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>3</td><td bgcolor='#eeeeec' align='center'>0.0798</td><td bgcolor='#eeeeec' align='right'>2901056</td><td bgcolor='#eeeeec'><a href='http://www.php.net/call_user_func_array' target='_new'>call_user_func_array</a>
<tr><td bgcolor='#eeeeec' align='center'>4</td><td bgcolor='#eeeeec' align='center'>0.0798</td><td bgcolor='#eeeeec' align='right'>2901224</td><td bgcolor='#eeeeec'>Piwik\Plugins\API\Controller->index( )</td><td title='/var/wwwc/piwik/core/FrontController.php' bgcolor='#eeeeec'>../FrontController.php<b>:</b>117</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>5</td><td bgcolor='#eeeeec' align='center'>0.0805</td><td bgcolor='#eeeeec' align='right'>2904808</td><td bgcolor='#eeeeec'>Piwik\API\Request->process( )</td><td title='/var/wwwc/piwik/plugins/API/Controller.php' bgcolor='#eeeeec'>../Controller.php<b>:</b>34</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>6</td><td bgcolor='#eeeeec' align='center'>0.0817</td><td bgcolor='#eeeeec' align='right'>2930184</td><td bgcolor='#eeeeec'>Piwik\API\Proxy->call( )</td><td title='/var/wwwc/piwik/core/API/Request.php' bgcolor='#eeeeec'>../Request.php<b>:</b>220</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>7</td><td bgcolor='#eeeeec' align='center'>0.0831</td><td bgcolor='#eeeeec' align='right'>2958128</td><td bgcolor='#eeeeec'><a href='http://www.php.net/call_user_func_array' target='_new'>call_user_func_array</a>
<tr><td bgcolor='#eeeeec' align='center'>8</td><td bgcolor='#eeeeec' align='center'>0.0831</td><td bgcolor='#eeeeec' align='right'>2958744</td><td bgcolor='#eeeeec'>Piwik\Plugins\VisitsSummary\API->getVisits( )</td><td title='/var/wwwc/piwik/core/API/Proxy.php' bgcolor='#eeeeec'>../Proxy.php<b>:</b>212</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>9</td><td bgcolor='#eeeeec' align='center'>0.0831</td><td bgcolor='#eeeeec' align='right'>2958856</td><td bgcolor='#eeeeec'>Piwik\Plugins\VisitsSummary\API->getNumeric( )</td><td title='/var/wwwc/piwik/plugins/VisitsSummary/API.php' bgcolor='#eeeeec'>../API.php<b>:</b>118</td></tr>
<tr><td bgcolor='#eeeeec' align='center'>10</td><td bgcolor='#eeeeec' align='center'>0.1130</td><td bgcolor='#eeeeec' align='right'>3355816</td><td
ERROR: 2 total errors during this script execution, please investigate and try and fix these errors. First error was: Got invalid response from API request: http://it.cathopedia.org/piwik/index.php?module=API&method=VisitsSummary.getVisits&idSite=1&period=day&date=last520&format=php&token_auth=6862472f689dfbae97a714f8bf274219&trigger=archivephp. Response was '<br />
Please read the error messages, they are different from the one reported in this topic:
See: http://piwik.org/faq/troubleshooting/faq_131/
Ok, raising memory_limity I got rid of the error, but now I have all the dayly statistics, but I don’t see the data for some weeks, months, and years
You’re right, Matt – sorry about that. I checked my log files and the Segmentation faults were happening for a long time…
So you fixed our main problem with the patch posted in this thread and archiving works again.
I took a look at the FAQ you mentioned and while there is PDO_MYSQL configured in Piwik’s global.ini.php our installation had an old entry “adapter = MYSQLI” in the config.ini.php. I deleted this entry to switch back to PDO_MYSQL and the Segmentation faults are gone. Archiving now works completely without errors.
Thanks for your help.
Thorsten
Aaargh! upgrading to 2.0.3 after patching like above gave me:
( ! ) Fatal error: Call to undefined method Piwik\Config::getFromDefaultConfig() in /var/wwwc/piwik/core/Plugin/Manager.php on line 484
Call Stack
1 0.0001 223208 {main}( ) …/index.php:0
2 0.0060 363080 Piwik\FrontController->init( ) …/index.php:61
3 0.0161 1213144 Piwik\Plugin\Manager->loadPlugins( ) …/FrontController.php:340
4 0.0161 1217920 Piwik\Plugin\Manager->reloadPlugins( ) …/Manager.php:526
5 0.0162 1222896 Piwik\Plugin\Manager->isPluginThirdPartyAndBogus( ) …/Manager.php:642
6 0.0162 1223000 Piwik\Plugin\Manager->isPluginBundledWithCore( ) …/Manager.php:495
Call Stack
7 0.0167 1223320 Piwik\FrontController::triggerSafeModeWhenError( ) …/FrontController.php:0
8 0.0167 1224800 Piwik\FrontController->dispatch( ) …/FrontController.php:258
9 0.0190 1418968 call_user_func_array ( ) …/FrontController.php:117
10 0.0190 1419304 Piwik\Plugins\CorePluginsAdmin\Controller->safemode( ) …/FrontController.php:117
11 0.0227 1630928 Piwik\Plugin\Manager->returnLoadedPluginsInfo( ) …/Controller.php:365
12 0.0245 1646464 Piwik\Plugin\Manager->isPluginThirdPartyAndBogus( ) …/Manager.php:440
13 0.0245 1646464 Piwik\Plugin\Manager->isPluginBundledWithCore( ) …/Manager.php:495
Archiving too is unuseful:
/usr/bin/php5 /var/wwwc/piwik/misc/cron/archive.php --url=http://it.cathopedia.org/piwik/ > /var/log/piwik/piwik-archive.log
PHP Fatal error: Call to undefined method Piwik\Config::getFromDefaultConfig() in /var/wwwc/piwik/core/Plugin/Manager.php on line 484
PHP Stack trace:
PHP 1. {main}() /var/wwwc/piwik/misc/cron/archive.php:0
PHP 2. Piwik\CronArchive->init() /var/wwwc/piwik/misc/cron/archive.php:44
PHP 3. Piwik\CronArchive->initCore() /var/wwwc/piwik/core/CronArchive.php:140
PHP 4. Piwik\FrontController->init() /var/wwwc/piwik/core/CronArchive.php:736
PHP 5. Piwik\Plugin\Manager->loadPlugins() /var/wwwc/piwik/core/FrontController.php:340
PHP 6. Piwik\Plugin\Manager->reloadPlugins() /var/wwwc/piwik/core/Plugin/Manager.php:526
PHP 7. Piwik\Plugin\Manager->isPluginThirdPartyAndBogus() /var/wwwc/piwik/core/Plugin/Manager.php:642
PHP 8. Piwik\Plugin\Manager->isPluginBundledWithCore() /var/wwwc/piwik/core/Plugin/Manager.php:495
PHP Stack trace:
PHP 9. Piwik\FrontController::triggerSafeModeWhenError() /var/wwwc/piwik/core/FrontController.php:0
PHP 10. Piwik\FrontController->dispatch() /var/wwwc/piwik/core/FrontController.php:258
PHP 11. call_user_func_array() /var/wwwc/piwik/core/FrontController.php:117
PHP 12. Piwik\Plugins\CorePluginsAdmin\Controller->safemode() /var/wwwc/piwik/core/FrontController.php:117
PHP 13. Piwik\Plugin\Manager->returnLoadedPluginsInfo() /var/wwwc/piwik/plugins/CorePluginsAdmin/Controller.php:365
PHP 14. Piwik\Plugin\Manager->isPluginThirdPartyAndBogus() /var/wwwc/piwik/core/Plugin/Manager.php:440
PHP 15. Piwik\Plugin\Manager->isPluginBundledWithCore() /var/wwwc/piwik/core/Plugin/Manager.php:495
Still got this error in Piwik 2.0.3
PHP 5.4.24-1
timeout value 3600
INFO [2014-01-14 20:08:50] [91fe0] ERROR: Got invalid response from API request: http://xxx.yyy.com/index.php?module=API&method=VisitsSummary.getVisits&idSite=24&period=year&date=last3&format=php&token_auth=c8b5f7df73cd9cd49f9b0cca
2e0728b8&trigger=archivephp. Response was 'a:2:{s:6:“result”;s:5:“error”;s:7:“message”;s:192:"This report has been reprocessed since your last click. To see this error less often, please increase the timeout value in seconds in Settings
General Settings. (error: id 265 not found).";}’
reupload all files, looks like some files are not using 2.0…3
I reuploaded all the file, but when I archive I got error, with the recomendation to report on the forum:
First error was: Got invalid response from API request: http://mysite/piwik/index.php?module=API&method=VisitsSummary.getVisits&idSite=1&period=day&date=last52&format=php&token_auth=6862472f689dfbae97a714f8bf274219&trigger=archivephp. Response was '<div style='word-wrap: break-word; border: 3px solid red; padding:4px; width:70%; background-color:#FFFF96;'>
<strong>There is an error. Please report the message (Piwik 2.0.3)
and full backtrace in the <a href='?module=Proxy&action=redirect&url=http://forum.piwik.org' target='_blank'>Piwik forums</a> (please do a Search first as it might have been reported already!).<br /><br/>
Notice:</strong> <em>Undefined index: enable_load_data_infile</em> in <strong>/var/piwik/core/Db/BatchInsert.php</strong> on line <strong>67</strong>
<br /><br />Backtrace --><div style="font-family:Courier;font-size:10pt"><br />
#0 Piwik\Error::errorHandler(...) called at [/var/piwik/core/Db/BatchInsert.php:67]<br />
#1 Piwik\Db\BatchInsert::tableInsertBatch(...) called at [/var/piwik/core/DataAccess/ArchiveWriter.php:280]<br />
#2 Piwik\DataAccess\ArchiveWriter->insertBulkRecords(...) called at [/var/piwik/core/DataAccess/ArchiveWriter.php:97]<br />
#3 Piwik\DataAccess\ArchiveWriter->insertBlobRecord(...) called at [/var/piwik/core/ArchiveProcessor.php:313]<br />
#4 Piwik\ArchiveProcessor->insertBlobRecord(...) called at [/var/piwik/plugins/Actions/Archiver.php:464]<br />
#5 Piwik\Plugins\Actions\Archiver->insertTable(...) called at [/var/piwik/plugins/Actions/Archiver.php:440]<br />
#6 Piwik\Plugins\Actions\Archiver->insertPageUrlsReports(...) called at [/var/piwik/plugins/Actions/Archiver.php:430]<br />
#7 Piwik\Plugins\Actions\Archiver->insertDayReports(...) called at [/var/piwik/plugins/Actions/Archiver.php:101]<br />
#8 Piwik\Plugins\Actions\Archiver->aggregateDayReport(...) called at [/var/piwik/core/ArchiveProcessor/PluginsArchiver.php:95]<br />
#9 Piwik\ArchiveProcessor\PluginsArchiver->callAggregateAllPlugins(...) called at [/var/piwik/core/ArchiveProcessor/Loader.php:120]<br />
#10 Piwik\ArchiveProcessor\Loader->prepareAllPluginsArchive(...) called at [/var/piwik/core/ArchiveProcessor/Loader.php:74]<br />
#11 Piwik\ArchiveProcessor\Loader->prepareArchive(...) called at [/var/piwik/core/Archive.php:793]<br />
#12 Piwik\Archive->prepareArchive(...) called at [/var/piwik/core/Archive.php:612]<br />
#13 Piwik\Archive->cacheArchiveIdsAfterLaunching(...) called at [/var/piwik/core/Archive.php:554]<br />
#14 Piwik\Archive->getArchiveIds(...) called at [/var/piwik/core/Archive.php:494]<br />
#15 Piwik\Archive->get(...) called at [/var/piwik/core/Archive.php:343]<br />
#16 Piwik\Archive->getDataTableFromNumeric(...) called at [/var/piwik/plugins/VisitsSummary/API.php:112]<br />
#17 Piwik\Plugins\VisitsSummary\API->getNumeric(...) called at [/var/piwik/plugins/VisitsSummary/API.php:118]<br />
#18 Piwik\Plugins\VisitsSummary\API->getVisits(...) called at [:]<br />
#19 call_user_func_array(...) called at [/var/piwik/core/API/Proxy.php:213]<br />
#20 Piwik\API\Proxy->call(...) called at [/var/piwik/core/API/Request.php:220]<br />
#21 Piwik\API\Request->process(...) called at [/var/piwik/plugins/API/Controller.php:34]<br />
#22 Piwik\Plugins\API\Controller->index(...) called at [:]<br />
#23 call_user_func_array(...) called at [/var/piwik/core/FrontController.php:117]<br />
#24 Piwik\FrontController->dispatch(...) called at [/var/piwik/index.php:62]<br />
I re-deleted all the archive tables in the db, I keep getting the same error.
A weird thing I saw in archive program: archiving begun creating 2013_11 table, then 2013_12, then 2014_01, and it stopped there with the error.
The logical thing would be beginning with 2014_01 and keep backward.
I get the error with all the sites, even with those which have less visits.
Check your file config/global.ini.php is uploaded correctly from 2.0.3
