Hi everybody,
I am trying to access piwik from an API but I get an error saying plugin not activated while all plugins are active when I see from the admin. The way I have accessed the plugin is as follows:
The scenario is this:
I have two installations of Piwik: one to serve as the analytics tool and the other to perform API requests (do I need full installation for this?). I previously had Piwik 1.2 for making API requests and that’s when I had that plugin not activated error. Now, since both Piwik installations are of same version, making an API call should work, but I still get error. For example, while performing UsersManager.addUser operation, I get the following error:
Thanks. It works fine now. Superuser token should be added. And also, it also requires something more; Piwik frontend should be instantiated first. Only then, all API requests will execute, otherwise, we will get no access error.
