Hi there,
I get the following error in “SEO Ranking”.
There is an error. Please report the message (Piwik 1.12) and full backtrace in the Piwik forums (please do a Search first as it might have been reported already!).
Warning: file_get_contents(http://www.whois.com/whois/abc.de): failed to open stream: Connection timed out in /var/www/xyz.de/piwik/core/Http.php on line 395
My Piwik instance is running on an Amazon EC2 Instance. Can that cause the error?
If modified the timeout in the “seo rankingchecker” php file from 10s to 30s.
Has anyone the same problems?
Thanks for your help.
