Hi All,
I am having trouble with a report being sent. When i click send now it comes up with problems.
When i tried it with gmail setting it came up with " Connection Timed Out"
I dont want to use gmail anyway, but was simply testing
I have Piwik installed on say www.server1.com
I am trying to instruct Piwik to send an email from my email account info@server2.com
These are hosted on same account, but no matter what settings I put in it just keeps saying emails cant be sent.
Any ideas anyone??
Ideally I would like email to come from info@mywebsitebusinessname.com
Or do i have to actually install Piwik under that domains directory on my hosting??
i have piwik installed on "rood/admin/piwik"
What is your hosting provider?
Have they a mail server?
can you send mails wen the mail settings are “off” ( no settings from you )?
When I turned off send via SMTP and then tried sending the report I got the following.
An error occured while sending ‘PDF Email Report - 1.2013-07-14.2.en.pdf’ to quantumphotography@gmail.com. Error was ‘Temporary local problem - please try later’
I am with " Justhost"
?? I presume they have mail server. The address I want it sent from is an actual email address I have setup in cpanel.
check if ther is a error log in your root of piwik
i couldnt see 1, in which folder might the file hide
the folder whete the piwik index.php is
No nothing there, as yu will see here from screenshot
http://screencast.com/t/Hhf3mu3vFDO
