I have a site that allows you to download files, and each file has a different link because there is a token that is generated for each download (for certain needs) example blabla.com/files/file.txt?token=blablabla.
The problem is that I end up with tens of thousands of different links in the Downloads category. Is it possible to make it count only as a link, or in the worst case not track the downloads anymore? (in addition to the parameter token, the download links are located in subdomains of the main domain)
Also, before accessing the download link, the user accesses a download page which also contains a token in parameter. For this page, if I understand correctly I only have to add the name of the parameter (example âtokenâ) in the âglobal list of query url parameters to exclureâ?
Therefore, visitors who visit the page with different tokens will be considered as if it were the same page without parameters in the url, right?
Hallo Outline, yes, the _paq.push([âenableLinkTrackingâ]); is also for tracking downloads. But by this, the tracking of all link clicking is disabled. See here:
scroll to
The matter ist, downloads are also links. For a solution, you can create a JavaScript function with a span element for downloads like (with enableLinkTracking and donât track downloads):
