Device Detector Set Values manually
is it possible to set the values of DeviceDetector manually with php ?
My goal is :
If $device['model'] == '' && $device['brand'] == '' && $device['type'] == 'desktop'
then i ll set :
$device['brand'] = 'PC';
$device['model'] = 'PC - '.$os['name'];
so i wont have unknown brands or models in my table.
furthermore i ll check for other types e.g. tv, if there is a unknown brand or model (or year -
i addet this to the devDetector) then i ll save the user_agent in a table to analize that agent
and place some additional infos in related tables. I have some special information about
user_agents from tv devices. In future, if there are some unknown device values i can check my tables and
put this infos to piwik (for some ua´s you need additional info tables because with some you cant get all
informations by pharsing the ua).
Just now i need a way how to put all device detector values into piwik manually. That means i dont want that
piwik pharses the ua and writes recognized device values by itself. I use the piwiktracker.php at the moment,
this class creates a http call like :
http://myStatsServer.com/piwik.php?idsite=X&token_auth=secretToken& ... &brand=BS&type=5
I put some additional values like type and brand, but this dont work. How i can implement that?
Thx and sry for bad english :wink:
same problem.
could you solve it ?
