Database connection help
I am new to this community , I would like to thank you in advance for helping me out.
I would like to know how to connect to matomo database? someone else installed matomo on the website.
Manisha
Well, it is your database, so you should have the password :slightly_smiling_face:
More seriously: If you don’t have the password details anymore, look into the config/config.ini.php file. There you can find the MySQL host/username/password that Matomo uses.
