I integrated piwik in one of my online portal. This portal generally help users to generate new mobile sites. What i want to do capture the analytics for the user created site. Now i want to capture more fields like if user accessing from mobile, then from which operator he is coming, circle, mobile number (do not worry about this data, i get this data as my project ip is white listed by the operator), how can i increase this type of fields in piwik so that i can show the report to the user with this type of information using piwik.
I facing the same problem, i get the MSISDN via header enrichment. I’d like to store the user phone number of each access, capturing the “x-nokia-calling-id” header.
Is possible to capture HTTP headers ?
cheers !
You can use Custom Variables, see the doc Custom Variables Analytics - Analytics Platform - Matomo
For custom work or pro services, please contact us at: http://piwik.org/consulting/
