marc17
#1
Hello Piwik,
We have the following tracking code,
We also reference the javascript files from http://spservices.codeplex.com in the head section of our masterpage…
However the custom variable doesnt appear - anything we are missing?
Cheers.
Marc.
matthieu
(Matthieu Aubry)
#2
if you add
var userName = [...]
console.log(userName); // or alert(userName);
does it display the username / popup ?
marc17
#3
Hi Matt,
Code now looks like this a) is this correct, if so, it doesnt appear still.
Many Thanks for your assistance.
matthieu
(Matthieu Aubry)
#4
change the code lines with:
piwikTracker.setCustomVariable(1, "Login_name", userName, "visit");
alert(userName);
piwikTracker.trackPageView();
then it should display the user name in the popup. if popUP shows empty, it means your username is not set correctly
