Hi all,
I’m trying to get a custom variable setup to track in piwik and having some difficulty (i’m new to all of this stuff and limited knowledge of js).
Basically i have a page ID being generated via JS somewhere in the heading area of the my page and stored in a variable called pageID.
var pageID = "${page.id?c}";
When i view the source, I can see that the value is set correct (var pageID = 525618);
So I wanted to reuse this variable in the footer of the page for piwik tracking. I used it like this:
_paq.push(['setCustomVariable', 1, 'pageid','pageID', 'visit']);
But this doesn’t actually work. When I view the source, the variable name shows up in the piwik code above…not it’s value of 525618.
Any help on what i can do? If i do console.log (pageID), it shows 525618.
Thank you.
