jr_ewing
(jr-ewing)
January 6, 2011, 11:01am
1
i get an error, when crontab is calling the archive shell script.
Version is 1.1.1
MAILTO=tom@xxxxxxx.de
5 * * * * /kunden/homepages/16/xxxx/htdocs/piwik/misc/cron/archive.sh > /dev/null
Error Message
Notice: Undefined index: SCRIPT_NAME in /homepages/16/dxxx/htdocs/piwik/core/Url.php on line 123
Backtrace -->#0 Piwik_ErrorHandler(8, Undefined index: SCRIPT_NAME, /homepages/16/dxxx/htdocs/piwik/core/Url.php, 123, Array ([url] => )) called at [/homepages/16/dxxx/htdocs/piwik/core/Url.php:123]#1 Piwik_Url::getCurrentScriptName() called at [/homepages/16/dxxx/htdocs/piwik/core/Url.php:45]#2 Piwik_Url::getCurrentUrlWithoutQueryString() called at [/homepages/16/dxxx/htdocs/piwik/core/UpdateCheck.php:41]#3 Piwik_UpdateCheck::check() called at [/homepages/16/dxxx/htdocs/piwik/plugins/CoreUpdater/CoreUpdater.php:75]#4 Piwik_CoreUpdater->updateCheck(Piwik_Event_Notification Object ([_notificationName] => FrontController.checkForUpdates,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))#5 call_user_func_array(Array ([0] => Piwik_CoreUpdater Object (),[1] => updateCheck), Array ([0] => Piwik_Event_Notification Object ([_notificationName] => FrontController.checkForUpdates,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))) called at [/homepages/16/dxxx/htdocs/piwik/libs/Event/Dispatcher.php:284]#6 Event_Dispatcher->postNotification(Piwik_Event_Notification Object ([_notificationName] => FrontController.checkForUpdates,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0), 1, ) called at [/homepages/16/dxxx/htdocs/piwik/core/PluginsManager.php:531]#7 Piwik_PostEvent(FrontController.checkForUpdates) called at [/homepages/16/dxxx/htdocs/piwik/core/FrontController.php:251]#8 Piwik_FrontController->init() called at [/homepages/16/dxxx/htdocs/piwik/index.php:59]
matthieu
(Matthieu Aubry)
January 7, 2011, 12:09am
2
vipsoft
(vipsoft)
January 7, 2011, 1:30am
3
im having the same kind of problems on version 1.1.1, but my email message says: no permission
but the .sh file permission is sett at 777, and i applyed the patch file fix, but still know luck.
matthieu
(Matthieu Aubry)
February 17, 2011, 8:35pm
5
budgirless, did you check the script group? try to run the command in: How to Set up Auto-Archiving of Your Reports - Analytics Platform - Matomo in “Test the cron command” it will run the script as your cron user
[quote=matthieu]
budgirless, did you check the script group? try to run the command in: How to Set up Auto-Archiving of Your Reports - Analytics Platform - Matomo in “Test the cron command” it will run the script as your cron user[/quote]
FIXED!!
i got it to work on ubuntu with your [dev.piwik.org ] patch & the wget command.
example: “5 * * * * wget http://mydomain.com/piwik/misc/cron/archive.sh ” thats all no /dev/null or anything else.
email example: [i]HTTP request sent, awaiting response… 200 OK
Length: 3291 (3.2K) [text/x-sh]
Saving to: `archive.sh.2’
0K ... 100% 250M=0s
2011-02-17 22:40:02 (250 MB/s) - `archive.sh.2’ saved [3291/3291][/i]
Thats its now right, i dont need to do any-else do I?
vipsoft
(vipsoft)
February 17, 2011, 11:49pm
7
wget fetches a copy of the script; wget doesn’t execute it
[quote=vipsoft]
wget fetches a copy of the script; wget doesn’t execute it[/quote]
so any idea’s what i can do to execute this file in ubuntu’s crontab?
UPDATE: ok so i managed to sort it out part of the problems was a wrong path that i added, but i now have a new error about the php &mysql, here is some of the log file:
[b]PHP Warning: Module ‘mysql’ already loaded in Unknown on line 0
Starting Piwik reports archiving…
Archiving period = day for idsite = 1…
<?xml version="1.0" encoding="utf-8" ?>
[/b]
