I have a cron error issue after upgrading Piwik from 0.5.4 to 0.5.5. I had upgraded manually and it went smoothly. Note that the cron did work for a day or two. But today, I received the following error:
/home/exquisit/public_html/analytics/misc/cron/archive.sh: line 51: 61189 Segmentation fault: 11 (core dumped) $CMD
According to my host, the code starting at line 51 is the following:
for period in day week year; do
CMD="$PHP_BIN $PIWIK_PATH -- module=API&method=VisitsSummary.getVisits&idSite=all&period=$period&date=last52&format=xml&token_auth=$TOKEN_AUTH";
$CMD
echo ""
done
Can you run archive.sh manually from the command-line (shell)? If you’ve enabled core dumps, the stack trace might help you pinpoint whether the crash is in php core or an extension.
It has been many years since I’ve used FreeBSD, so I would advise looking to the FreeBSD forums for guidance.
Can you run archive.sh manually from the command-line (shell]When I ran the shell script from the command line, I received an out of memory error:
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 3145728 bytes) in /home/exquisit/public_html/analytics/core/Archive/Single.php on line 435
I doubled the memory allocation and tested again, and it worked.
